Activity Forums Blackmagic Design Message for Kristian Lam
  • Message for Kristian Lam
    Posted by Chris Borjis on August 16, 2006 at 6:21 pm
    I upgraded to the latest firmware on our multibridge today.
    The HD to SD hardware downconversion on channel B is now working! 🙂
    I noticed that If I left the channel B connected and did an SD project with downconversion off, it ouputs the same signal as if its on channel A.
    Question:
    Can I just leave it plugged into channel B for HD and SD editing?
    Will that work ok going to digibeta?
    I’d like to leave it on channel B so I don’t have to manually reconnect to A for SD projects.
    Kristian Lam replied 20 years, 1 month ago 2 Members · 1 Reply
  • Kristian Lam
    August 17, 2006 at 4:42 am
    Yes, you can leave it on channel B output even when you turn off down conversion.
    regards
    Kristian Lam
    Blackmagic Design
