Activity › Forums › Adobe Illustrator › Merging two non-overlapping shapes in Illustrator CC
  • Merging two non-overlapping shapes in Illustrator CC
    Posted by Tine Korsic on January 26, 2017 at 2:58 pm
    Greetings,
    as the titles says, I’m having issues with joining two shapes which do not overlap in Illustrator CC.
    Explanation in the screenshots:
    For example, I would like to merge the two objects selected, in the top-left https://prnt.sc/e0mdy2
    The thing is, those two object do not overlap, as seen when I move the inside object out https://prnt.sc/e0mgk9
    Anyways, the outside shape is not a stroke https://prnt.sc/e0mhab
    Any help would be appreciated.
    Vincent Rosati replied 9 years, 8 months ago 2 Members · 4 Replies
  • Vincent Rosati
    January 27, 2017 at 12:05 am
    Select both objects and use Pathfinder > Unite.
    Vince
    *Please remember to Like an answer if it solves your question or gives you a good idea.
  • Tine Korsic
    January 27, 2017 at 7:30 am
    Thanks for the swift answer but I’ve already tried that. and that’s what happens:
    https://prnt.sc/e0x2dt
    https://prnt.sc/e0x2pl
    The whole rectangle around the objects turns into the fill color. I have no idea why.
    Please help.
  • Tine Korsic
    January 27, 2017 at 7:45 am
    Update – I think it has something to do with the clipping masks. Is there a way to convert them into objects?
    btw, I’m pretty new with Illustrator, therefore I apologize for dumb questions.
  • Vincent Rosati
    January 28, 2017 at 12:24 am
    Hmmm. Could be.
    A few other things to try first..
    Object > Expand, then try Unite.
    Or, as you suspect, Object > Clipping Mask > Release, then Unite.
    If you can’t get it to work, consider uploading the file and we’ll fix you up.
    Vince
