Activity Forums Maxon Cinema 4D Merging Objects/Polygons into one?
  • Merging Objects/Polygons into one?
    Posted by Amit Parekh on June 12, 2013 at 10:25 pm
    Okay so, maybe I did this the long way or something, but I’m working with polygons and now I have a bunch of them which are on different objects, but all next to each other (with their edges touching). (How) can I merge these together into one polygon/object so I can then use the cloth on it?
    Ak.
    Adrian Stiegler replied 10 years, 1 month ago 7 Members · 8 Replies
  • 8 Replies
  • Adam Trachtenberg
    June 13, 2013 at 2:18 am
    Use the Mesh>Commands>Optimize function to weld abutting edges.
  • Darby Edelen
    June 13, 2013 at 4:28 pm
    If the polygons belong to different objects I think you’ll need to select those objects and use Mesh > Conversion > Connect Objects before you Optimize the resulting mesh.
    I very often use Connect and Delete as I don’t normally need the separate objects any longer. If you just use Connect then the separate objects will still exist and you’ll have a new object that contains all selected objects as polygon groups.
    Either way the new Connected object can be Optimized.
    Darby Edelen
  • Amit Parekh
    June 13, 2013 at 6:36 pm
    Thanks. Worked like a charm.
  • Drew Smith
    August 24, 2014 at 3:47 pm
    haha! exactly what I was looking for. Thanks guys!
  • David Cabestany
    April 21, 2015 at 4:14 pm
    Hey guys quick question,
    I created and extruded object out of 684 paths I imported from Illustrator, then I separated them into separate objects and then I made them editable, now I have 684 groups of one poly plus to caps and i need them each to be one object, but when I use Connect objects and delete with everything selected all of them get merged into one single giant object.
    Is there a way to connect and delete all of them at once but still keep them as separate objects? I don’t want to do that on each group of objects.
    Thanks in advance,
    D.
  • Brian Jones
    April 22, 2015 at 2:51 am
    do the Connect and Delete, then Optimize, then follow by using Mesh/Conversion/Polygon Groups To Objects
  • David Cabestany
    April 23, 2015 at 6:25 pm
    Thanks man, but it didn’t work. Once I connected and deleted the positions changed, mybe becuase I had effectors applied already.
    Best,
    D.
  • Adrian Stiegler
    July 15, 2016 at 4:03 pm
    Great technique. Thank you! For any noobs like, Connect and Delete is in the right click when you have the path selected.
    Cheers dude!!
