Activity › Forums › Maxon Cinema 4D › Merge two objects into one?!
  • Merge two objects into one?!
    Posted by Filip Stillerska on January 15, 2019 at 8:09 pm
    I know that this has been asked before, but I’ve spent the last couple of hours trying to figure out how to merge/connect two (or more) polygon objects into one, single mesh. A lot of people have mentioned the “Connect Objects”- and “Connect Objects + Delete”-commands, but they don’t seem to appear for me:
    I’m currently using the latest version of Cinema 4D Lite that comes bundled with After Effects.
    Brian Jones replied 7 years, 8 months ago 3 Members · 4 Replies
  • Brian Jones
    January 15, 2019 at 8:54 pm
    that’s the places to look so those commands must not be in Lite, the only alternate I know of is MagicMerge but that doesn’t work in Lite either.
  • Emir Bojorquez
    January 15, 2019 at 11:00 pm
    Not sure if C4 Lite has Connect object.
    Try to go to Create>>>Modeling>>>Connect
    If you have it, you could drop all your objects inside, select them all and make it editable to create one sigle object.
    Good Luck
    Imagination is the best tool…
  • Filip Stillerska
    January 16, 2019 at 1:46 pm
    I guess there is no way to achieve this in C4D Lite then…
    Not a huge deal though, I can always place multiple objects as children under the same null which produces a similar result.
  • Brian Jones
    January 16, 2019 at 2:43 pm
    it still should be possible to just copy/paste the polys from one object into the other, and does Lite have the Boole object? You could do a Boole Union if it’s there and then make that editable
