Activity Forums Adobe After Effects merge several composition
  • merge several composition
    Posted by Shai Russo on June 17, 2012 at 10:21 am
    Hello,
    I’ve created multiple composition and I want to render them and merge them unto one video file.
    How can i do it from outside of ae? Is there any render command that merge the files or the aepx?
    thanks
    Kevin Kershaw replied 10 years, 8 months ago 4 Members · 3 Replies
  • Tudor “ted” jelescu
    June 17, 2012 at 2:52 pm
    If I understand correctly your question, you can create another comp, bring all individual comps in it, put them on the same timeline in the desired order and render out.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Marc Estrada
    July 7, 2014 at 5:30 pm
    how do you combine comps into one comp so you can render as one movie? I make comps and I copy and paste comps into one main comp, I know there has to be a better way to this, thanks
  • Kevin Kershaw
    December 9, 2015 at 2:21 pm
    Sorry to pull up an old topic but I had the same question and noticed that I could select a group of compositions, right click and choose ‘New Comp from selection…’
    Then I checked ‘Sequence layers’.
    The order was reversed when selecting the folder of compositions, but selecting the compositions themselves seemed to work.
    (Using Adobe AE CC 2014)
