Activity › Forums › Apple Final Cut Pro › Merge clips
  • Merge clips
    Posted by Oliver Peters on July 18, 2012 at 12:39 am
    Any way to merge clips in the FCP 7 way? I have a set of camera and WAV files that will not properly synchronize. Don’t have PluralEyes on this machine. Do have clapsticks.
    For the moment, I’m opening the video clip in its own timeline and adding the WAV as a connected clip based on the clap. Then muting the camera’s audio track. Works, but seems more cumbersome than merging. Plus, there’s no option to select for how to merge other than doing it manually. Ideas?
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
    Oliver Peters replied 14 years, 2 months ago 3 Members · 4 Replies
  • David Eaks
    July 18, 2012 at 1:47 am
    Just thought I’d mention that I have been able to get FCPX to sync clips (that wouldn’t sync properly otherwise) by letting FCPX analyze the camera audio for both loudness and background noise. Even if the analyzed result sounded terrible to me, FCPX could sync the clips, then I just turn off the loudness and background noise audio enhancements.
  • Oliver Peters
    July 18, 2012 at 2:03 am
    [David Eaks] “Just thought I’d mention that I have been able to get FCPX to sync clips (that wouldn’t sync properly otherwise) by letting FCPX analyze the camera audio”
    Thanks. I’ll at least give that a try in the AM. The clips started to sync on the first one and then just wouldn’t. Checked for any background processes but nothing was impeding the sync. I still think a proper merge lips function would be a useful feature.
    – Oliver
    Orlando, FL
  • Bill Davis
    July 18, 2012 at 2:20 am
    Oliver,
    Have you tried any of the “assisted sync” techniques that X supports? Adding an initial marker to each part of an audio and video sync pair – even a very gross one, can give X a starting point and “focus” it on not having to look at every sample of every clip.
    FWIW.
    “Before speaking out ask yourself whether your words are true, whether they are respectful and whether they are needed in our civil discussions.”-Justice O’Connor
  • Oliver Peters
    July 18, 2012 at 11:17 am
    Yes, I added markers but it didn’t make any difference. Thanks.
    Oliver
    Orlando, FL
