Activity Forums Audio Merge Audio into .mov Files
  • Merge Audio into .mov Files
    Posted by Janis Huber on June 23, 2015 at 9:41 am
    Hi there
    On the current project I would like to ‘bake’ the Audio right into the .MOV (2K Alexa) using
    the time code. So far I tried to use BF_QT Merge, but it doesn’t really do the job. Do you
    know any other software where you can synch the Audio right into the quick time file?
    I don’t really want to do it in Premiere, cause you have to merge
    clips (changes names of the clips) to synch by time code.
    I hope my question is understandable.
    Cheers
    Bouke Vahl replied 11 years, 3 months ago 3 Members · 2 Replies
  • Ty Ford
    June 23, 2015 at 1:46 pm
    Hello Janis and welcome to the Cow Audio Forum.
    If the duration of the video and audio are exactly the same, you can use Quicktime 7 Pro to delete and add audio files.
    There’s probably a handier way to do it, but I haven’t had to figure that out.
    Regards,
    Ty Ford
    Cow Audio Forum Leader
    Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
    Ty Ford Blog: Ty Ford’s Blog
  • Bouke Vahl
    June 24, 2015 at 1:13 pm
    Janis,
    Since I’m the developer of BWF_QT merge, what does not work?
    Do note, there was some Alexa firmware that made the files write protected, so you could not insert in them.
    But that was a couple of years ago.
    Do mail me direct if you like, you’re entitled to support.
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pros
