Activity › Forums › Adobe Premiere Pro › Mercury Transmit?
  • Mercury Transmit?
    Posted by Jim Scott on May 12, 2012 at 3:25 pm
    Mac OS 10.6.8
    Black Magic Intensity Pro – Desktop Video 9.5
    Quadro 4000
    CS6
    Can someone please explain how to set up Mercury Transmit? The only way I can get external monitoring to work is to use a Blackmagic preset as was required before CS6.
    Jim Scott replied 14 years, 4 months ago 2 Members · 3 Replies
  • Gerry Curtis
    May 13, 2012 at 1:45 am
    Hi Jim,
    Under preferences>playback you should have a box that says Video Playback with a Blackmagic Playback option that you check.
    Cheers,
    Gerry
    http://www.digitalkilnstudios.com
    http://www.savasanafilm.com
  • Jim Scott
    May 13, 2012 at 3:17 am
    Thanks Gerry.
    I do have that option checked, and I do get external monitoring as long as I set up a Blackmagic preset. My understanding of Mercury Transmit was that you didn’t need to use a Blackmagic preset in order to get external monitoring, but that Premiere would take care of the linking regardless of which preset you are using. Maybe I’m confused?
  • Jim Scott
    May 13, 2012 at 3:34 am
    Ok, I’ve got it working now… I think. When adding clips of different video frame sizes and aspect ratios to a sequence, as long as I select “Keep Sequence Settings” when the Clip Mismatch Warning window pops up external monitoring keeps working. But if I make a new sequence from a clip that doesn’t match the project settings (or I select “Change Sequence Settings” in the Clip Mismatch Warning) external monitoring disappears. I obviously did not understand Mercury Transmit, but at least I’ve got a handle on it now.
