Activity › Forums › VEGAS Pro › mercalli vegas 9 issue
  • mercalli vegas 9 issue
    Posted by Jason Barczewski on October 24, 2009 at 8:45 pm
    I’m getting an error from prodad when i try to start video analysis.
    the error comes up many times and says:
    Missing assign (‘=’) after word ‘Video’ in render template ‘proDAD-MercalliHD 1080-24p’
    Sample: Video = blabla
    No Vegas render template existing for this video format.
    Remedy:
    Create a new render-template in Vegas for the used video-format.
    So I created a new render template according to the specifications but that hasn’t helped.
    I’m running the latest version of Mercalli. I went and got the update from their site and added it but it hasn’t helped.
    Any ideas?
    Svetlin Marinov replied 12 years, 2 months ago 4 Members · 3 Replies
  • John Rofrano
    October 25, 2009 at 8:19 pm
    You best option is to contact proDAD and explain the attributes of your files. It sounds like it is something they weren’t expecting.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Jim Burke
    May 27, 2010 at 4:25 pm
    Jason, I have the same problem. I had Mercalli working fine on Vegas 8, but I run into the issue you are describing in Vegas 9. Have you figured out a solution to this?
  • Svetlin Marinov
    July 4, 2014 at 10:40 am
    I have found the solution to this. You need to match the Project Settings to the media that you want to stabilize.
