Mercalli V2
Posted by Andrew Peralta on September 24, 2010 at 3:09 pmThe Mercalli V2 export process always stops at %48. Anyone know why?
Greuter Daysy replied 16 years ago 4 Members · 9 Replies -
Stephen Mann
September 25, 2010 at 2:44 amNope.
But if you’ll tell us more about your system we might be able to venture a guess.
Steve Mann
MannMade Digital Video
http://www.mmdv.com -
John Rofrano
September 25, 2010 at 12:34 pmYea, please tell us more. What error are you getting? What are your PC specs? (number of cores and memory) How much free hard drive space? What file formats are you rendering to? etc.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Andrew Peralta
September 25, 2010 at 8:41 pmIt is an HP Pavillion laptop. 4GB Ram, Intel Pentium Processor, 2 cores, 3.0 Gigahertz. 230 GB free space left. The stabilizing is great but I can’t get it to export. It always stops. Any suggestions?
Greuter Daysy
September 26, 2010 at 7:15 amDid you exporting as AVI?
Some AVI codecs make trouble.
You should exporting as WMV – this works better for me. -
Andrew Peralta
September 26, 2010 at 7:55 amYeah, but doesn’t the wmv quality suck more than the avi?
John Rofrano
September 26, 2010 at 1:58 pmWell… you still didn’t tell us what format you are trying to render to.
Because you are going to edit the file coming out of Mercalli, you should always use a codec that uses very light intraframe compression for intermediaries. Preferred intraframe codecs are: DV, M-JPEG, CineForm, or Lagarith. All of theses use an AVI container and all of these work with Mercalli and edit smoothly in Vegas Pro.
~jr
Andrew Peralta
September 26, 2010 at 6:59 pmI tried to export to AVI. All of them but all stop export at 49%.
John Rofrano
September 27, 2010 at 12:02 amMaybe there is corruption in the video file at that point or many you are running out of memory. How long is the clip you’re trying to stabilize? Can you cut it into shorter clips?
~jr
Greuter Daysy
September 27, 2010 at 5:50 amThe Mercalli WMV export creates a high-quality wmv-clip.
I am using this format and the quality is very well.
