Activity › Forums › Adobe Premiere Pro › Mercalli V2 export AVI problem
  • Mercalli V2 export AVI problem
    Posted by Alain Zagar on May 17, 2011 at 12:45 am
    I apologize for posting here but there doesn’t seem to be a more appropriate place to ask this question.
    I’m using Mercalli V2 to stabilize a lot of hand help footage and it works OK inside of Adobe Premiere CS5 as an effect ( only interlaced files give good results). I was hoping that someone here has also tried to see if the stand alone version of Mercalli exports to AVI. I haven’t been able to export to a single AVI file since I purchased version 2 many months ago. I’ve asked for help from ProDad but their suggestion to update to the latest version was not helpful. Of course I would have tried that first.
    If I re-encode these mts files to any other file format and use that with Mercalli it seems to work. This seems like a waste of time to me and I have a lot of clips so I don’t want to do this.
    Mercalli V2 seems to begin exporting but it stops after 1 second with “export finished” and no error messages.
    I’m working directly with Canon Vixia HFS100 files. Windows 7 64 bit, Ultimate.
    Previewing stabilized clips in Mercalli stand-alone V2 looks great. Problem is with export.
    I would appreciate knowing if anyone is using the stand alone version and exporting successfully to AVIs? Can you share your export settings and general experience with Mercalli stand alone V2.
    Alain
    Here is a typical file that doesn’t work correctly.
    MediaInfo
    Video
    Menu ID : 1 (0x1)
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : High@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 2 frames
    Codec ID : 27
    Duration : 3mn 2s
    Bit rate mode : Variable
    Bit rate : 22.8 Mbps
    Maximum bit rate : 22.7 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 29.970 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Bits/(Pixel*Frame) : 0.367
    Stream size : 497 MiB (95%)
    Greuter Daysy replied 15 years, 4 months ago 2 Members · 1 Reply
  • Greuter Daysy
    May 20, 2011 at 2:32 pm
    proDAD is working on the next update. With a better export.
    Send an email to prodad and get the new version.
    gd
