Activity Forums Adobe Encore DVD menu transitions
  • menu transitions
    Posted by Kaye Woods on March 24, 2011 at 9:46 pm
    I’m moving over from Apple’s DVD Studio Pro to Adobe Encore. In DVDSP, it’s super easy to make a menu transitions from either menu to menu or menu to movie with a nice fade or whatever you want. It’s as easy as clicking on the menu, and choosing what type of transition you want in a drop down box.
    I can’t find anything like that or even anything that looks like an option to have transitions between menus. Am I missing something?
    Jon Geddes replied 15 years, 5 months ago 2 Members · 1 Reply
  • Jon Geddes
    March 28, 2011 at 12:16 am
    You can set a menu transition in the transition tab of a button’s properties. So for a button, you would set the target, and then you would set the transition to that target.
    There are no pre-made transitions available in Encore. You must create your own, import as an asset, then assign it as the transition for a button. Since you can only set a single file as a menu transition, your file must contain both audio and video (assuming you want audio for your transition).
    Jon Geddes
    http://www.precomposed.com
