Activity Forums Adobe Encore DVD Menu transition with motion
  • Menu transition with motion
    Posted by Jason Cork on May 24, 2009 at 5:12 pm
    Not sure exactly how I achieve this…
    I have a static menu that when I press the ‘play’ button, before the film starts playing, I want an effect I have created in After Effects to play (the AE file has the same menu, with an effect applied to it), and after that the film starts. I hope that makes sense! What is the best way to achieve this?
    Jon Geddes replied 17 years, 4 months ago 2 Members · 1 Reply
  • Jon Geddes
    May 24, 2009 at 7:59 pm
    With the button selected that will play the movie, in the properties panel, you should see a ‘Transition’ tab. Set the transition to the asset of your transition animation. It can only link to a single asset, so if you want audio with it, you should create an After Effects composition that has the video and audio of your transition and import it into encore using dynamic link.
    Jon Geddes
    Motion Graphics Designer
    http://www.precomposed.com
