Activity Forums Adobe Encore DVD Menu showing chosen picture
  • Menu showing chosen picture
    Posted by Víctor Galdón on September 28, 2009 at 7:58 am
    Hi:
    I don’t know if it is possible but here I go:
    I need a menu where you can see pictures as thumbnails/buttons and beside them the chosen one higher at the same time. I would choose another picture and becomes the higher picture of the menu so you can see the chosen picture and buttoms at the same time.
    Now the big question: is this possible? :-S
    Thanks.
    Victor
    Jon Geddes replied 16 years, 12 months ago 2 Members · 1 Reply
  • Jon Geddes
    September 28, 2009 at 3:37 pm
    Only possible if you create a separate menu for each button. The menus would all look the same of course, except for the chosen picture. You would then have to create pseudo buttons with auto-activate turned on for the navigation, so that when you navigate down from button one, it auto-activates the next menu which displays the image for button 2. It’s a very complicated setup and causes problems with software dvd players (mouse-over does not cause auto-activate of next button). Also, any audio or motion you have for the menu will start over each time a button is highlighted. Usually people avoid this type of menu setup, but I have seen it on professional discs (Seinfeld TV Show DVD)
    Jon Geddes
    http://www.precomposed.com
