Activity Forums Adobe Encore DVD Menu problems & improper playback
  • Menu problems & improper playback
    Posted by Midwestmonsters on May 8, 2007 at 5:12 am
    I have 1 timeline with 5 chapter points. I want my 5 titles on the menu to link to each chapter point. “Title 1” to “Chapter 1” etc.
    After each chapter plays, I want the DVD to return to the chapter menu. I thought I had it figured out and the Check Project showed no errors.
    When I preview in Encore, it appears to function correctly. yet, when I burn the DVD and play it, the menu pops up correctly, I can select a chapter, but then the disc skips through all the chapter points and then stops! So, if I select Chapter 1 on the menu, it will skip through 2-3-4-5 very quickly and then stop the disc.
    Suggestions for a correction? Or what the heck is going on?
    Thank you
    George Wing replied 19 years, 4 months ago 2 Members · 5 Replies
  • George Wing
    May 8, 2007 at 11:43 am
    Which version of Encore are you using? You could use Chapter END-LINKS, or Chapter Playlists in Encore DVD 2.0
    Depends on how you want your DVD to play — if you need a PLAY-ALL, or if you always want to return to the menu after chapter play…
    Regards,
    George
  • Midwestmonsters
    May 8, 2007 at 1:30 pm
    I’m on 2.0 I do not need a Play All and always want it to kick back to the menu after each 10 minute chapter is viewed.
    I’m also not familiar with the Chapter End-links function.
    Jason
  • George Wing
    May 8, 2007 at 9:57 pm
    Select a chapter, and under the Chapter properties set the END-ACTION to go back to the menu.
    Regards,
    George
  • Midwestmonsters
    May 8, 2007 at 11:12 pm
    After looking at my timeline further it dawned on me I haven’t been clear in my descriptions. My timeline is NOT one large m2v/ac3 segement, I have 5 different pieces on the timeline with each segment’s beginning being a chapter point. Is this an incorrect way to operate Encore?
    I could encode all 5 into 1 piece, but didn’t want to redo it if I don’t have to.
    My Chapter points currently are set as END Action — Menu 1 Default
  • George Wing
    May 8, 2007 at 11:20 pm
    How about just creating 5 separate timelines (one for each video clip — or Title). Then your menu buttons just link to the appropriate timeline, and the Timeline End Action goes back to the menu.
    Regards,
    George
