Activity › Forums › Adobe Encore DVD › menu help
  • Jim Watkinson
    October 2, 2008 at 6:23 pm
    Hi Kenny,
    I am pretty sure that is all you can get out of the “roll-over” type function from Encore, at present. The best you’ll be able to do is change the alpha of the tint you want.
    I thought that was sort of limiting, myself.
  • Joe Bowden
    October 2, 2008 at 6:41 pm
    You can do this using multiple menus, using the button auto-activate feature.
  • Kenny Manley
    October 2, 2008 at 6:57 pm
    Could you please elaborate a little more on how to go about doing this?
  • Joe Bowden
    October 2, 2008 at 7:08 pm
    Easy…in your example, create two menus, each having the image you want displayed. Then on the original menu, link each button to the correct menu. Then set each button on the original menu to auto-activate.
    The result will be when the viewer selects a button, it will automatically go to the next menu.
    The only drawback is that on a software DVD player, the user will have to click the button to go to the next menu – but this is the common drawback to all workarounds limitations of menus in DVD-Video.
  • Kenny Manley
    October 2, 2008 at 7:27 pm
    Cool. Thanks a lot.
