Activity Forums VEGAS Pro Menu based Bluray read as data disk
  • Menu based Bluray read as data disk
    Posted by Paul Gregory on June 20, 2014 at 1:05 am
    I has doing a test burn of a project onto a Blu-ray re writable disk. When I tried to play it on my Samsung ‘Smart’ player it suggested that it was a data disk & asked me to select music, video or pictures. I thought at first that the problem might have been the player since it had just undergone a firmware upgrade. So to test this I took both an old DVD & a previously authored Blu-ray & they played perfectly.
    I had made a couple of small last minute changes to the project before It was rendered out. I was wondering if there is anything that could have altered the burn to suggest that the project has anything other than a menu based disk?
    Thanks in advance
    John Rofrano replied 12 years, 2 months ago 3 Members · 7 Replies
  • 7 Replies
  • John Rofrano
    June 20, 2014 at 2:25 am
    [Paul Gregory] “So to test this I took both an old DVD & a previously authored Blu-ray & they played perfectly.”
    Was the other Blu-ray disc also on re-writable media? It could be the re-writable media that is making it think it’s a data disc.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Paul Gregory
    June 20, 2014 at 2:33 am
    The other had originally been written onto the same Blu-ray disk & when it worked OK I just burned it onto a normal disk.
    Thanks in advance
  • John Rofrano
    June 20, 2014 at 2:41 am
    [Paul Gregory] “The other had originally been written onto the same Blu-ray disk & when it worked OK I just burned it onto a normal disk.”
    Yea, but you changed the firmware so maybe the new firmware is acting strange with BD-RE discs? Try burning the old project back to the BD-RE disc and see if it still works. I don’t think there is anything you could have done to your new project to make it not be recognized as a menu based disc. You can always take it to a store and try their Blu-ray players just to check.
    BTW, Blu-ray has had it’s share of dropping support with firmware upgrades so it’s not uncommon that something will stop working when a firmware upgrade is applied. Some manufactures did drop support for menu based discs on “burned” not “pressed” media as a feeble attempt at thwarting illegal Bu-ray copying. I think they have stopped that now but that’s an example of how silly this whole Blu-ray licensing things has become.
    ~jr
  • Stephen Mann
    June 20, 2014 at 12:55 pm
    … but that’s an example of how silly this whole Blu-ray licensing things has become.
    You would think they would have learned from the real-world of CD’s and DVDs. If I can see it (hear it), I can copy it. The Blu-Ray encryption was sold as absolutely unbreakable, and even if it was, broken encryption could be modified through a database update on the newer BD discs themselves. Ever wonder why it takes so long for a BD player to start a new disc? The player is updating its’ database of encryption keys.
    It took only a month for the BD encryption to be cracked. Again, by a kid (like the CSS crack on DVDs).
    Yet, they persist, thinking they are somehow preventing pirating.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • John Rofrano
    June 20, 2014 at 4:49 pm
    [Stephen Mann] “Ever wonder why it takes so long for a BD player to start a new disc?”
    They haven’t learned anything. We don’t watch Blu-ray’s anymore at my house because they are so slow. I have better things to do than wait 5 minutes while a Blu-ray disc spins up and finally gets to a menu. We went back to buying only DVD’s.
    ~jr
  • Paul Gregory
    June 21, 2014 at 1:56 am
    I would agree with you inasmuch as all formats seem to be just transient. Blu-rays never sold enough to warrant the investment. Both Blu-rays & DVD’s will eventually completely make there exit as people are finding it easier to create home networks & have media players.
    I also agree that the Blu-rays are very slow to start & can sometimes be very noise until they start playing.
    It would be a pity though to loose the features of Blu-rays like chapter markers,multiple audio tracks & subtitles that you can turn on/off. MKV allow for some of these features to be retained & played by a media player sourced from DVD’s.
    I seem to recall reading that there is also some programs around that can do the same thing with iso files for both DVD’s & Blu-rays but I can’t recall its name. The good thing about this is that you might be able to keep all of the features like motion menus & scene selection menus.
    As for my problem disk I had a lot of problems erasing it. I thought it might be best to just give the project a new name & just re burn it. I found that DVDA just wanted to use my old ISO files. I eventually copied the project & the preview said that the disk would be erased. It didn’t erase correctly since I had part of current project & older data as well. I erased the disk in Windows & another authoring program as well & DVDA still said it wanted to erase, but I finally had it burn OK. Presumably I had a faulty disk.
    Thanks in advance
  • John Rofrano
    June 21, 2014 at 11:33 am
    [Paul Gregory] “Both Blu-rays & DVD’s will eventually completely make there exit as people are finding it easier to create home networks & have media players.”
    I don’t see this happening any time soon because manufacturers seem to to be incapable of creating a media server. Everyone expects you to run a PC to watch TV. That’s never going to fly. I have a Buffalo Linkstation NAS that runs 24/7 serving up files in my home. If that thing could be a proper media server, I would be all set. It supports DLNA and tries to be a media server but it falls far short. I have an Apple TV and Apple doesn’t seem to have a clue how to solve this either. They also want you to have a Mac open running iTunes. Why is it these big companies are so clueless when it comes to streaming home media? This isn’t a hard problem to figure out and, IMHO, Apple is in the best position so solve it but they don’t seem interested. 🙁
    ~jr
