Activity Forums Apple Final Cut Pro Legacy memory usage settings
  • memory usage settings
    Posted by John Crossfield on August 4, 2009 at 9:49 am
    Hi, just added ram to our 2008 oct mac pro, to help boost work on FCP, had 4gb (4x 1gb sticks, 2 in each side) replaced these with 4 x 4gb sticks in same sockets and moved the 4x 1gb stick over to the empty sockets. Under ‘this mac’ it now shows as 20gb ram (phew!!) but when I go into FCP6 settings and try to up the memory usage it remains at 2gb max (100%), I assumed originally that it could only use ram from 1 ram socket (ie with 2gb of the original 4gb installed). How do I get it to access more of the ram??
    This might be a stupid question, I just might be being thick!!
    cheers
    John
    Jeremy Garchow replied 17 years, 1 month ago 2 Members · 1 Reply
  • Jeremy Garchow
    August 4, 2009 at 1:14 pm
    Fcp can only access that much ram due to it’s 32bit infrastructure. It will need to be rewritten to 64 bit to take advantage of more RAM.
