Activity › Forums › Adobe After Effects › Memory & Cache
Walter Soyka
March 9, 2010 at 2:23 pmA couple questions for you: Are you running Windows or Mac? How many processors? How much RAM? How many drives do you have attached to your system? What kind of work do you do? What kind of footage files are you working with?
I think that the only reason for moving these folders from their defaults would be to increase performance. When you render, are your CPUs working near maximum load? Is your memory usage maxed out? If either of these is the case, your disks are not a bottleneck and it doesn’t matter where you store files. If your RAM and CPU usages are low during render, then redistributing your files and getting faster drives may help.
Personally, Image Cache doesn’t do me much good, because I never use standard preview (spacebar). It’s not realtime, and it doesn’t include audio, so I don’t use it. I always use RAM preview (0 on the numeric keypad) or shift-RAM preview (Shift key and 0 on the numeric keypad; it functions the same as regular RAM preview, but you can specify different settings to trade off between speed and quality).
I don’t think where the project file is located impacts performance; it’s not accessed much except during opens and saves.
I don’t have much personal experience with Conformed Media Cache, because I always use intraframe-compressed footage to improve AE’s rendering speed and reliability. The only items in my cache are PEK files (audio waveform previews) and a few CAF files (conformed audio files), so I don’t think I’d see much benefit from relocating this folder.
Take a peek in your cache folder; if there’s a lot of video, you might relocate it to a footage drive, but again, disk speed may not be your rendering bottleneck.
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Nina Bjer
March 9, 2010 at 3:03 pmThank you ever so much for all you help! 🙂 I had no idea this could possibly be this complicated, but I’ll do like you said and hopefully i’ll work! Again, thanks so much!
Nina Bjer
March 9, 2010 at 3:26 pmI’m on a Windows laptop.
Core(TM)2Duo CP T7500 @2.20GHz
4 GB Ram
I have one external harddrive that I previously only used for backup but now for the render files.
I make films of one to four minutes, with filmed hd footage
Quicktime or Windows Media files, and animate this sometimes, one film had 300 layers, effects etc.
I don’t know about the cpu-usage or memory usage, but will try to check this… although ofcorse I don’t know how to do that either… oh! 🙂 -
Ross Tokach
March 12, 2010 at 11:12 amTry using CS4 instead of FCP. Then create your timeline normally, open a sequence that is 1/4 resolution , change your slider to fit, cut the film. Highlight everything and copy it. Open the tab for the originial native HD timeline and paste that sucker in there. Hit enter and go to the fridge. Come back export directly into aftereffects, render, go to walk the cat, come back and start your effects. Export it as full losseless quicktime.
“Oop, I think my render is done!”
Nina Bjer
March 12, 2010 at 1:16 pmThanks very much for the tip! I can’t use CS4 on my computer, only CS3, not good enough unfortunately, but when I get a better computer and CS4, i’ll remember you tip! 🙂
