Activity › Forums › Live Events & Streaming › Meetings in 4 Rooms must be recorded & live streamed with DSK on EACH with ONE operator
Posted by John Ferguson on July 6, 2017 at 2:09 pmI am needing to develop a system that will record 4 rooms (one camera each), record & live stream, and downstream key each output. The trick is, I can only have one operator.
I am thinking of getting 4 ATEM switchers with 4 Hyperdecks.
Can I hook up 4 ATEM switchers to one computer or would I need 4 computers (with a KVM)?
Any advice would be appreciated.
Kevin Copeland replied 8 years ago 7 Members · 9 Replies -
Chuck Johnson
July 11, 2017 at 3:07 amHi John,
How far apart are the rooms?
How about audio?
In terms of downstream key, is it a logo or bug?
Does the facility have enough bandwidth for four live streams?Chuck Johnson
Big Bad Wolf Creative Group
817-429-0818 -
Bouke Vahl
July 11, 2017 at 6:47 amHi John,
How about one computer with a decklink quad, and some software?
This thing could do it:
https://www.videotoolshed.com/product/recorder/
It’s an FFmpeg front end. I can adjust it to add the DSK, and configure it for your streaming.
(Not sure if you stream to YouTube or elsewhere.)This way you’re done for a fraction of the money, with way less hardware.
Bouke
http://www.videotoolshed.com -
John Ferguson
July 11, 2017 at 2:16 pmRooms are in adjacent office rooms in a hallway. Very close.
Audio will be recorded via Shure MXA910 in each room. DSK is a lower third graphic describing the meeting name.
Bandwidth should not be a problem as this is a government building. -
Mark Suszko
July 13, 2017 at 6:57 pmWhy not add the DSK at each of the cameras?
https://www.markertek.com/product/burst-hdlg/burst-electronics-hdlg-hd-sd-sdi-color-logo-generator
Jeff Pulera
July 26, 2017 at 4:55 pmNewtek TriCaster would be very well-suited to this project. The only caveat is that you can only encode one stream at a time, except with TC1 model which has 2 encoders. Meaning, you would have to take 2 video outputs from TriCaster into stand-alone streaming encoders for additional streams. Or could use a PC with a dual-input streaming card such as Osprey perhaps.
Newtek NDI is video over the network, with no latency and excellent quality. Newtek just introduced the NDI Connect Spark. It’s a $495 box that takes in an HDMI source and converts to NDI – plug unit into the network and video travels to any device on the network (SDI version also available). Put a Spark in each room, and no need to run video cabling all over – use existing network jacks.
Using TC1 (or other TriCaster model with Advanced Edition upgrade), you would have 8-16 NDI inputs available over the network (plus HDMI or SDI inputs depending on model). All 4 cameras can come in via NDI, or physical connection. If you don’t want to use the venue’s network, pick up an inexpensive network hub ($50) and run your own Cat-6 between rooms to connect all sources to TriCaster.
TriCaster has 4 M/E buses. Route 1 camera to each bus, and use the M/E Keyers to add unique graphics to each source. There are 4 of these Keyers (DSKs) per M/E. TriCaster can record up to 4 sources at once to the hard drive as high-quality .mov with 4:2:2 quality, plus 2 additional sources as H.264 format.
The TC1 would be able to take in all 4 cameras either as SDI or NDI, add appropriate graphics via DSK to each source, record each source, and stream 2 of those sources via internal encoders. There are 4 SDI outputs – configure sources 3 and 4 to output as SDI and route to external streaming encoder (about $500-1000 per unit, various vendors).
TC1 is $15k. Could pull this off with a TC Mini at $8k (Mini HD4 with Advanced Edition software added). Mini would encode 1 stream internally, route 2 unique HDMI outputs to external encoders, and for 4th stream…NDI to another computer which would stream that source.
None of these are inexpensive, but they are ideal solutions to do what you need to do.
Since Newtek allows other vendors to use NDI without charge, it is gaining rapid adoption. For instance, vMix and other software switchers are now integrating NDI into their products. You may be able to build your own PC with vMix and add appropriate video cards to the system and achieve similar results to TriCaster workflow. Would require vMix 4k or PRO version. This would be less expensive than TriCaster if you are comfortable with the “build your own” workflow.
If you’d like to discuss options further, check our website for contact info – https://www.sharbor.com
Jeff Pulera
Safe Harbor Computers -
Jeff Pulera
July 26, 2017 at 4:59 pmI will also add that PTZ camera manufacturers are now adding native NDI output to their cameras. Panasonic and PTZ Optics will both be offering NDI soon, and Newtek just introduced their own camera, the NDIHX model.
NDI offers a one-cable solution with NDI PTZ cameras. ONE network cable can offer Power, Video, and Control of the PTZ camera! Imagine one operator being able to view, control, record, and stream programs from 4 rooms simultaneously…
The future is here!!!
Jeff Pulera
Justin Toney
October 22, 2017 at 4:27 amI’ve been using VMIX lately with a blackmagic quad card in the computer. I’ve been doing a live streaming show with several cameras, audio, commercials, graphics and etc. and I can do this by myself. The app has a web interface which allows you to have macros set and utilize an ipad or tablet to fire off your commands. For example I have a command to goto commercial, one for dissolve back into camera, and stuff like that.
The support isn’t great but the manual does help figure things out. For the money its not too bad. Plus it has the NDI interface so many are going with these days.
Word of warning on the titler though, I don’t like it and it needs help. Most of the time I just create what I need in photoshop and run titles that way.
Kevin Copeland
September 25, 2018 at 3:38 pmAs far as a titler, here is an inexpensive solution. You just need a computer or laptop that supports 3 displays. Hook 2 displays to your switcher for key and fill. It uses PowerPoint and generates an alpha channel. simplesupers.com It keeps all of PowerPoints animations and transitions. Very cool.
