Activity Forums Media 100 media100 clip lost of synchro in edit suite
  • media100 clip lost of synchro in edit suite
    Posted by Macmauro on November 7, 2005 at 7:57 am
    please, can you understand what kind of problem is this?
    I was working in m100 8.2.2 (os 10.3.3- quicktime 6.0, G4 dual 1,25)
    the clip was ok just one minute before, suddenly i try to
    drag it on the timeline: impossible, the red cross appears on the hand dragging
    What has happened? I push play in the edit suite
    and i discover this clip has lost synchro with audio.I can’t understand why (i was using just one audio track of this clip, the second was deselected), the only solution i find is to reimport the a1 a2 and video files from the disk. Now the clip is ok, i can drag it on the timeline. Twenty minutes later m100 crashes, “unable to switch to selected deck”.
    I’m doing an important work, i’m afraid to have problem again
    (I use external scsi 2 lvd HD 10.000rpm with an “initio miles U2” controller- 1 maxtor and 1 fujitsu i inserted in an external box dual place, they work fine but the disk utility and mac os system info don’t recognize the correct id scsi number, instead of 8 and 9 they say 0 and 15).
    Thank you for the help
    Maurizio
    Macmauro replied 20 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
