Activity Forums Media 100 Media100 can’t find Kona 3
  • Media100 can’t find Kona 3
    Posted by Gerry Condez on June 6, 2012 at 5:20 am
    Installed Snow then Installed version 2.1, No selection for Kona 3 within midi 100. I tried to upgrade to Lion and still no Kona can be seen within Media 100 A/V option. Why? Need advise.
    Kona version downloaded was KONA 3 NDD Driver Version 10.3.1, Control Panel, and Notes
    Gerry Condez replied 14 years, 2 months ago 2 Members · 2 Replies
  • Michael Hanish
    June 6, 2012 at 10:16 am
    Gerry,
    You need to use an earlier version of the Kona driver as specified in the release notes, I think 9.05 or 9.06, until a Media100 update allows use of newer Kona drivers. MAke sure you uninstall the Kona software using the Uninstaller, restart, then install the correct version.
    Hope this helps,
  • Gerry Condez
    June 6, 2012 at 12:37 pm
    [Michael Hanish] “Gerry,
    Hope this helps,
    Thanks Mike, I saw the Kona back in Media 100. I used the 9.05. Took me a while to install everything fresh last night and I lost track of what version I installed. I probably installed all the latest version since they work with Final Cut X trial but now it does not show the A/V out for FCX, that does not matter anyway. Just checking if the kona card was installed right. Thanks again.
