Activity Forums Avid Media Composer media tool
  • media tool
    Posted by Jim Leser on September 20, 2010 at 3:10 pm
    I have a question regarding clearing media using the Media Tool. It’s been awhile since I did this and have some questions. I’m running Xpress Pro 5.8 and needed to make room on a 230 gb internal hard drive on my Mac. I opened the Media Tool, then highlighted a particular project where I had used the internal drive to store media on, etc. Instead of deleting just the media, I also deleted the pre-computes and master clips for the project since I won’t need to work on it again.
    – Did I actually delete the media for that project on this internal drive?
    – Can I use this drive for future projects? Has this drive been compromised
    in any way?
    I would like to use this drive as I have several external drives, daisy-chained to a G5 Mac and have had some playback issues on some projects because they’re connected.
    As I said, it’s been a while since I used the Media tool.
    Thank you in advance
    Matt Mullen replied 16 years ago 2 Members · 3 Replies
  • Matt Mullen
    September 20, 2010 at 8:08 pm
    If you selected the media then yes you deleted it.
    The media tool wouldn’t compromise your drive. Did you see space free up?
  • Jim Leser
    September 20, 2010 at 8:19 pm
    Hello,
    I deleted the media, the precomputes ( which I understand are the effects ) and the master clips, as it’s a very old project and I won’t be working on it again. Did this cause any problems?
    Jim
  • Matt Mullen
    September 20, 2010 at 8:20 pm
    What problems are you having?
