Activity Forums Adobe Premiere Pro Media Pending FOREVER
  • Media Pending FOREVER
    Posted by Alex Gamble on August 28, 2009 at 10:21 pm
    Hey –
    So, I’ve definitely read a couple of other threads concerning this topic, but the answer wasn’t entirely clear on what needs to be done.
    I’m working on a pretty big project right now in Premiere CS4 (with 80-100gigs of footage), and recently I’ve been having a lot of problems with importing mpegs.
    The problem is, I’ll import an MPEG2 file and it will remain in “Media Pending” indefinitely. An X sometimes appears at the bottom right corner that reads something like “file is busy, couldn’t be imported,” without a loading bar (although I am doing NOTHING at all with the file). Long story short, all of my imported files were previously a different format (sources from different cameras) but were converted to all be the same frame rate/frame size/format, and the program just seems to be picking out random files that it doesn’t want to open. I’ve sort of fixed the problem before by re-exporting the original file to the SAME exact format type and it doesn’t end up in pending hell, but I really don’t want to have to wait an extra hour just to export it again.
    I’ve read that sometimes deleting the preview files can fix it? However, I don’t want to go deleting things prematurely at this point, because I’ve got hours of rendered frames and not enough time to deal with.
    Ideas? Suggestions? Anything would be greatly appreciated at this point and time.
    Alex Gamble replied 17 years ago 2 Members · 2 Replies
  • Vince Becquiot
    August 29, 2009 at 1:08 am
    I would convert whatever you have left to something less taxing to the system. Even Uncompressed would be better.
    Where are the files coming from?
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Alex Gamble
    August 29, 2009 at 2:47 am
    It’s a multi-cam edit of a concert used from different “fan” cameras (so file types ranged anywhere from 4:3 .mov files to 16:9 .mxf files). I tried to convert every file so that I could lay it right into the timeline to sync with the master audio without having to render and find out later that it wasn’t in sync with the music at all. In other words, it’s been a big pain in the bum.
    Any suggestions on different file types if the project itself is AVCHD 1080p24 Anamorphic and I’m usually exporting files at MPEG2 1080p?
