Activity Forums Adobe Premiere Pro Media Pending Forever
  • Media Pending Forever
    Posted by Charlie Herrick on April 1, 2019 at 4:35 pm
    Everything was working fine a couple months ago, however, all my media was scattered around in different drives/folders. I consolidated them all into one drive/folder, and relinked everything within Premiere. It seemed to be successful.
    Now I am trying to do another export of the timeline in higher-quality and it just gets stuck forever. I noticed that all my clips are displaying “Media Pending” and even if I let it sit for a full day, nothing changes.
    I tried several solutions I found online including:
    – Close large timelines and bins, save, close and reopen Premiere
    – Un-enable and re-enable all clips in timeline
    – Delete and reload Premiere’s preferences
    – Make small tweaks to a clip, such as adding a cut or removing/adding a frame
    – Create a new sequence and copy-paste everything from the old one into the new one
    None of this has worked.
    The timeline claims the media is “offline”, which begs two questions:
    a) Why doesn’t it just say “Media Offline” instead of “Media Pending”?
    b) What was the point of spending all that time relinking my media after I moved my files?
    Whenever I right-click a clip in the timeline in an attempt to relink it from there, I get the Beach Ball of Death and have to force quit.
    I need to get this exported within the next couple days and since it needs to be maximum quality, I know the render is already going to eat up a lot of that time so I need to find a solution quickly…
    Any suggestions are appreciated! Thanks.
    Charlie Herrick replied 7 years, 5 months ago 2 Members · 2 Replies
  • Todd Perchert
    April 1, 2019 at 6:33 pm
    One thing I see you didn’t try. Import your sequence into a new Project. Then try your export again.
    TC
  • Charlie Herrick
    April 2, 2019 at 3:54 pm
    Thanks! Great idea; however when I tried to import a sequence from that file, the dialogue listed nothing. I’d previously saved another version of the project and that too listed no sequences.
