Activity › Forums › Apple Final Cut Pro › Media Online, need to take offline without deleting and reconnect to a backup drive
  • Media Online, need to take offline without deleting and reconnect to a backup drive
    Posted by Daniel Elder on July 8, 2015 at 8:22 pm
    My drive is crapping out on me and what is happening is that the media that I captured with that drive is very glitchy and I didn’t realize it until I had synced up my changed my metadata, linked up my four cameras and sound and started to edit the footage. Now my problem is, I don’t know how to take this media offline and then batch capture my footage with all the same information from my backup drive. My backup drive has a different name, so don’t know if I need to rename it?
    Also, I copy and transcoded all the media to a drive holding the library, so all my footage is stored on an external drive. So DRIVE A has library and copy / transcoded media DRIVE B & C have all the raw media.
    Anyway, I hope someone can help me as I’m trying to finalize my rough edit tonight.
    Dan
    Daniel Elder
    producer
    http://www.elderpictures.com
    Bret Williams replied 11 years, 2 months ago 2 Members · 2 Replies
  • Daniel Elder
    July 8, 2015 at 8:46 pm
    I cannot figure out a way to make the media offline and then relink it to my backup drive, everything I am looking at doesn’t seem to make it possible?
    Daniel Elder
    producer
  • Bret Williams
    July 8, 2015 at 9:30 pm
    If you need to relink your whole library, you can highlight the library in the browser. Then select all the media and choose file>relink files. Instead of checking the “missing” box check the “all” box. Then you should only need to point it to the new drive.
