Activity › Forums › Apple Final Cut Pro Legacy › Media Offline after reboot ‘eddia start and end’ different on reconect
  • Media Offline after reboot ‘eddia start and end’ different on reconect
    Posted by Ben Edwards on May 10, 2011 at 3:28 pm
    I used Log and Transfer to convert AVCHD footage to ProRes. I shutdown Mac and when I restarted and went into the project around 10 percent were offline. I did manage to reconnect but had to use reel and and clip name only and got a ‘Media start and end’ attribute warning.
    Anyone know what is going on?
    Ben
    Ben Edwards – Freelance Filmmaker
    https://www.funkytwig.com
    Ben Edwards replied 15 years, 4 months ago 2 Members · 12 Replies
  • 12 Replies
  • Chris Tompkins
    May 10, 2011 at 3:36 pm
    What drive(s) are your media(s) on?
    Chris Tompkins
    Video Atlanta LLC
  • Ben Edwards
    May 11, 2011 at 6:38 am
    Its a RAID 10 array of 2 2GB Samsung Spinpoint Drives. Its actually a NTFS file system with Paragon NTFS. I did spend some time on apple technical forums and people seemed to think that alough the free NTFS was to be avoided the paid for versions were OK.
  • Chris Tompkins
    May 11, 2011 at 10:39 am
    Is this internal SATA drives?
    Chris Tompkins
    Video Atlanta LLC
  • Ben Edwards
    May 11, 2011 at 10:45 am
    Its SATA drive in a RAID 10 enclosure connected to Mac via Fi rewire 800.
    Ben
  • Chris Tompkins
    May 11, 2011 at 10:50 am
    FCP is know for losing connection w/ media, so your problem is unique.
    FW connection to a raid should be solid.
    Sometimes finicky connected drives can lose connection to the comp and FCP gets wonky.
    Chris Tompkins
    Video Atlanta LLC
  • Ben Edwards
    May 11, 2011 at 12:20 pm
    I know stuff going off-line is common but having to tell FCP to ignore attributes is something that I thought is a lot less common. So you don’t think it is a NTFS thing?
    This tie I managed to reconnect but previously I totally lost some footage.
  • Chris Tompkins
    May 11, 2011 at 12:37 pm
    We format all drives Mac OS Extended
    Chris Tompkins
    Video Atlanta LLC
  • Ben Edwards
    May 11, 2011 at 1:00 pm
    They are formatted as NTFS.
  • Chris Tompkins
    May 11, 2011 at 1:04 pm
    NTFS has always been a windows HardDrive format, why are the drives your are using for editing on a mac formatted that way?
    Chris Tompkins
    Video Atlanta LLC
  • Ben Edwards
    May 11, 2011 at 1:08 pm
    Long story but when things are reorganised the will be Mac formatted. Was using Vegas and FCP7 but when FCPx comes along will probably transfer totally.
