Activity Forums Apple Final Cut Pro Legacy Media Manager recompress failed error code 49
  • Media Manager recompress failed error code 49
    Posted by Daniel Bellury on August 16, 2011 at 7:04 pm
    I’m working on a large project that was on Avid. I used Automatic Duck to get everything into Final Cut. Automatic Duck creates .MOV wrapper files to get FCP to read the Avid .MXF files.
    Wes at Autoduck recommended I use Media Manager to recompress the project, that way FCP isn’t relying on the .MOV wrapper files and is instead referencing actual .MOV files.
    Everytime I try using Media Manager (which I have used successfully many times with other projects, usually using the copy fuctions instead of recompress), I get errors and about 1/3 of my project shows up offline.
    A screen shot of the error is below. Any help would be greatly appreciated!!
    Daniel
    Jerry Hofmann replied 15 years ago 2 Members · 5 Replies
  • Jerry Hofmann
    August 16, 2011 at 7:14 pm
    Might try putting that errant file into compressor and doing the decompression there.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Daniel Bellury
    August 16, 2011 at 7:24 pm
    Thanks Jerry, but it’s multiple files and if I put the MOV wrapper file, is Compressor going to understand that it’s referencing an MXF file?
  • Jerry Hofmann
    August 16, 2011 at 7:30 pm
    If FCP sees it as a QT movie, so will Compressor.
    Something else… rebuild that single file from MXF again to QT wrapper, might be corrupt or something, and that could fix it.
    Jerry
    Current DVD:
  • Daniel Bellury
    August 16, 2011 at 8:08 pm
    Trying the Compressor solution. Looking good so far.
    As far as rebuilding, the AAF files that I Autoduck’ed to FCP are pretty substantial sequences and I don’t know that there’s a way to rebuild specific files.
  • Jerry Hofmann
    August 16, 2011 at 8:21 pm
    You’d have to ask Wes at Autoduck if there’s a way to just process a few clips…
    Jerry
    Current DVD:
