Activity › Forums › Apple Final Cut Pro Legacy › Media Manager Madness 1920 to 720 ntsc 24p
Posted by Peter Lee-jones on March 23, 2009 at 12:22 pmHi CC FCP,
when I media manage 1920×1080 24p to ntsc 24p it letterboxes it! why does it do that?
there seems to be no way to tell it to be anamorphic
let me know
thanks pete
Pinewood Studios, UK
Rafael Amador replied 17 years, 5 months ago 2 Members · 3 Replies -
Rafael Amador
March 23, 2009 at 3:27 pmHi Peter,
Your post is a bit confusing.
You talk about 1920×1080 to NTSC and to 720.
I made a try compressing some 1920×1080 with Media Manager and no problem to get the file 16×9.
I have compressed to PAL (I’m in PAL-land) and to 720p25.
If you want to compress to NTSC Anamorphic, you need to select one of the Anamorphic presets.
rafael(and here some clips for the friends: https://www.vimeo.com/2694745 )
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Peter Lee-jones
March 23, 2009 at 3:33 pmyes it is strange that the preset setting letterboxes the picture. But now if i make a custom setting i can make it anamorphic. Unfortunately there is no way to store the custom setting
Rafael Amador
March 23, 2009 at 3:48 pmHi Peter,
In the MM you can scroll down the list of the presets and you will find “Custom”.
This or you duplicate a Sequence preset and customize it.
This preset will show up as an option in MM.
