Activity › Forums › Apple Final Cut Pro Legacy › Media Manager doesn’t bring images for video masks in FCP 7
  • Media Manager doesn’t bring images for video masks in FCP 7
    Posted by Ben Knight on September 12, 2012 at 7:07 pm
    Hi all,
    The first time I tried to use Media Manager to move an 11 minute proRes sequence in FCP 7, it was a disaster.
    Then I read here you need your default Sequence settings set to the exact same setting as the timeline you’re trying to move, to make sure non time-coded audio files get moved.
    I tried again and it ALMOST worked. A couple of sound effect files still didn’t come across. (I’ll check again to make sure they’re in the original media folder for the project).
    And NONE of the images for some of the video masks were included… .is there a way to ensure they come across automatically?
    Ben Knight replied 13 years, 5 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    September 14, 2012 at 6:48 pm
    Copy and paste the sequence to the new project file, reconnect the media to that after you’ve moved it.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Ben Knight
    May 1, 2013 at 6:44 pm
    Thanks, Jerry. IN the end i manually added the mask file back in to the mask filter, but good to know for the future.
