Activity Forums Apple Final Cut Pro Legacy Media Manager – Backup
  • Media Manager – Backup
    Posted by Giuliano Bausano on February 23, 2011 at 10:26 am
    Hi all,
    i have a lot of files.mov, done with 5dmk2 and to work with them i did a single ProRes file..
    now i’ve finished the project and i need to backup it with media manager but i’d like to save only clips i’ve worked with, instead of all 30Gb of file.mov in ProRes.. is it possible please? any idea suggestion?
    tnx in advance.
    Giuliano.
    Giuliano Bausano replied 15 years, 7 months ago 2 Members · 4 Replies
  • Andrew Kimery
    February 23, 2011 at 4:14 pm
    First, go to the Browser window in FCP make sure each clip has a name or number associated with it in the “Reel” column. Now when you use the Media Manager check the “delete unused media” option and only the sections of media that are in the timeline will get backed-up.
    -Andrew
    3.2GHz 8-core, FCP 6.0.4, 10.5.5
    Blackmagic Multibridge Eclipse (6.8.1)
  • Giuliano Bausano
    February 24, 2011 at 10:34 am
    Tnx a lot for the answer
    but i just have ONE CLIP (3h long)
    i’d like to know if it’s possible to export/backup just the used/edited part.
    any idea pls?
  • Andrew Kimery
    February 24, 2011 at 7:00 pm
    What I said will do just that (only copy the sections of the clip used in the timeline). You just have to make sure the clip has a Reel number assigned to it in the Browser and that “delete unused media” is checked in the Media Manager window.
    -Andrew
  • Giuliano Bausano
    February 25, 2011 at 2:38 pm
    Tnx a lot for the answer Andrew (again :),
    clips doesn’t have a reel number or name associated, Reel field is empty..
    how to assign it, pls?
