Activity Forums Apple Final Cut Pro Legacy Media Manager and Freeze-Speed Triggers-Altered Speed
  • Media Manager and Freeze-Speed Triggers-Altered Speed
    Posted by Tom Daigon on November 9, 2008 at 2:34 pm
    Heres a thought to deal with MM’s finikyness with speed changes/freezes and such…
    I know baking in-exporting and importing is one approach. Since I use the “send to” function alot with Motion 3, how about this. Everytime you need a freeze or speed change or speed ramp….send the clip to Motion, create the speed effect, save the project then jump back into FCP. Theoretically it should work and take advantage of the quick work flow between FCP and Motion.
    Jerry Hofmann replied 17 years, 10 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    November 9, 2008 at 4:59 pm
    Good idea… the speed changes in Motion blow FCP’s away in any event!
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
