Activity › Forums › Apple Final Cut Pro Legacy › Media Manager and DV Start/Stop
  • Media Manager and DV Start/Stop
    Posted by Nate Schmidt on June 24, 2006 at 2:11 am
    So here is my question, if I capture an entire tape and use the dv start/stop detection is ther a way to use the media manager to create separate media files on my hard drive for each of the segments? and if there is how would I do that?
    Nick Meyers replied 20 years, 3 months ago 3 Members · 2 Replies
  • Kevin Monahan
    June 24, 2006 at 7:33 pm
    Sure. Just delete unused media. There is a HOW TO article on kenstone.net
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
  • Nick Meyers
    June 25, 2006 at 3:42 am
    nate,
    media manager will not work for this.
    it WILL work if you have trimmed or shortened the clips.
    then you can use Media Manager and delete unused as Kevin suggests.
    but Media Manager does this thing…
    if it sees 2 clips that share a frame, or even SHARE AN ADJACENT FRAME it will combine both clips into one file.
    So if you capture a tape, use DV start stop & makes subclips,
    a media manage will just copy the master file, and give it the name of your first subclip
    nothing else.
    you could media manage every SECOND clip, and it would work.
    but to get all the subs, you;d have to manage all the even numbered ones in one operation,
    then all the odd numbered ones.
    not going to happen!
    the way to do it is to use BATCH EXPORT
    https://www.lafcpug.org/tutorials/basic_batch_export.html
    Batch Export only works from the browser, not the timeline.
    select al the item you want to export, or the folder they are in,
    File Menu > Batch Export
    make self contained, use in/out
    this will create new, self contained files which you;d then import back into FCP.
    you’re then free to delete the original; file.
    cheers,
    nick
