Activity › Forums › Apple Final Cut Pro Legacy › Media Manager
Media Manager
Posted by Steve Cohen on November 27, 2007 at 7:15 pmCan you use Media Manager on projects were the media has been removed already?
I did a project 6 months ago and now I need to make a minor change to it for re-airing, but I only want to capture the footage that was actually used (with some handles).
Steve Cohen
Editor
O2 Media Inc.Steve Cohen replied 18 years, 10 months ago 4 Members · 7 Replies -
Dan Shott
November 27, 2007 at 7:30 pmYes, you can media manage a sequence without the media online. For shows that we send to online where the media is going to be redigitized we actually media managed it with the media offline. Here is the settings we use.
In media manager have it Create Offline clips then click Deleted unused media from duplicated sequence and click Use Handles (then select how long you want the handles to be). We usually uncheck everything else except Duplicated selected sequence and place in a new project.
This will created a new project with your sequence in it and a batch capture of this will bring in just the media in the sequence plus handles.
Dan Shott
November 27, 2007 at 7:31 pmYes, you can media manage a sequence without the media online. For shows that we send to online where the media is going to be redigitized we actually media managed it with the media offline. Here is the settings we use.
Dan Shott
Jeremy Garchow
November 27, 2007 at 7:33 pmWhat version of FCP?
This ‘feature’ was busted in a few versions of FCP.
Jeremy
Mark Raudonis
November 27, 2007 at 11:24 pmJeremy,
“Busted” only with regards to Multi-cam clips. Works as expected for everything else.
Mark
Jeremy Garchow
November 28, 2007 at 4:49 amNo, not really. I can’t remember the exact version numbers, but 4.5 this was busted and I think it was 5.1.2 but I am not sure. It was before multicam and after multicam.
Jeremy
Steve Cohen
November 28, 2007 at 12:44 pmclimbon321 Thanks for the suggestion.
I will try it.
As far as the version I am using 6.0.2.We’ll see if it works, it can’t hurt to try can it.
Thanks again.
Steve Cohen
Editor
O2 Media Inc.
