Activity Forums VEGAS Pro Media Library problems with Vegas 6
  • Media Library problems with Vegas 6
    Posted by Jim Murphy on September 25, 2005 at 12:34 pm
    I have been using Vegas 4 successfully, and am just now trying to get Vegas 6 working, but have been having trouble with the program not responding. I have uninstalled a couple of times, also removed MS SQL server and the Sony Media Manager. I have tried installing from the original Vegas 6 disc, then upgrading to Vegas 6c, and also tried just installing from the Vegas 6c download. Still getting the same trouble–the program does not respond. I got this error message recently: “The Media Library experienced an unrecoverable error. The Media Library will be closed.” The details were: “System.NullReferenceException: Object reference not set to an instance of an object.
    at System.Drawing.SafeNativeMethods.GdipMeasureString(HandleRef graphics, String textString, Int32 length, HandleRef font, GPRECTF& layoutRect, HandleRef stringFormat, GPRECTF& boundingBox, Int32& codepointsFitted, Int32& linesFilled)
    at System.Drawing.Graphics.MeasureString(String text, Font font, SizeF layoutArea, StringFormat stringFormat)
    at System.Drawing.Graphics.MeasureString(String text, Font font, SizeF layoutArea)
    at System.Drawing.Graphics.MeasureString(String text, Font font)
    at Sony.MediaSoftware.Controls.LinkLabel.EllipseTheTextIfNec(String originalText)
    at Sony.MediaSoftware.Controls.LinkLabel.set_Text(String value)
    at Sony.MediaSoftware.Controls.LinkLabel.LinkLabel_SizeChanged(Object sender, EventArgs e)
    at System.Windows.Forms.Control.OnSizeChanged(EventArgs e)
    at System.Windows.Forms.Control.UpdateBounds(Int32 x, Int32 y, Int32 width, Int32 height, Int32 clientWidth, Int32 clientHeight)
    at System.Windows.Forms.Control.UpdateBounds()
    at System.Windows.Forms.Control.WmWindowPosChanged(Message& m)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.Label.WndProc(Message& m)
    at System.Windows.Forms.LinkLabel.WndProc(Message& msg)
    at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
    at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)”
    Any help with this would be appreciated. Thanks, Jim
    Edward Troxel replied 20 years, 12 months ago 4 Members · 9 Replies
  • 9 Replies
  • Chris Young
    September 25, 2005 at 3:02 pm
    Had similar problems when I first installed V6 on WinXP SP1. They weren’t resolved until I went to WinXP SP2 plus updating the Microsoft .Net Framework to v1.1 SP1, plus I think there may even have been another patch I added after that. If you don’t have these items installed it may be, just may be the cause of your problems. I know it resolved all our Media Manager issues. Good luck.
    Chris Young
    CYV Productions
    Sydney
  • Jim Murphy
    September 25, 2005 at 6:26 pm
    Thanks. I have not installed SP2, because it kept making my system crash when I tried several times. I hope there’s another solution! Thanks, Jim
  • Jim Murphy
    September 26, 2005 at 2:54 am
    Anyone using Vegas 6 successfully with Windows Service Pack 1? TIA, Jim
  • Edward Troxel
    September 26, 2005 at 3:13 am
    XP-SP1 here with .NET 1.1 SP 1. Works fine here.
    Edward Troxel
    JETDV Scripts
  • Graham Bernard
    September 26, 2005 at 12:07 pm
    XP Pro here. SP 1. Using Media Manager daily. Upgraded to Vegas 6c still working fine.
    Grazie
  • Jim Murphy
    September 29, 2005 at 4:11 am
    I can get Vegas 6 working, but not 6c (not responding, as above). Not sure what is going on. I’m wondering if there is an advantage to trying 6b. Jim
  • Edward Troxel
    September 29, 2005 at 1:50 pm
    Version 6.0 was on some original CD’s but was NOT the release version. The first officially released version was 6.0a but it had many problems. Version 6.0b made it stable enough for me to start using it. Version 6.0c fixes even more problems and is what I am now using. I would NOT go below 6.0b.
    Edward Troxel
    JETDV Scripts
  • Jim Murphy
    September 30, 2005 at 3:08 am
    Is 6.0b available somewhere? I see only 6.0c on the website, and I had not downloaded 6.0b. Thanks, Jim
  • Edward Troxel
    September 30, 2005 at 1:37 pm
    I’m sure many people are like me and have it burned on a CD. However, I don’t know where you can download it from. Why not use 6.0c?
    Edward Troxel
    JETDV Scripts
