Activity Forums Apple Final Cut Pro Legacy Media from PC to Mac / Avid to FCP
  • Media from PC to Mac / Avid to FCP
    Posted by Marcosh on August 23, 2006 at 2:02 pm
    Hi everyone,
    I have a new gig in which I’ll have to capture some media on a PC – probably using Adrenaline or Avid Xpress and bring the material home to my FCP station.
    I haven’t got the specifics of the job yet but I was told I’d be working from some DigiBeta source material / DV50 compression. I know FCP can handle that but my question is how can I best bring the footage into my system? I have an external HD that I was planning to use as my storage device but am I going to have a problem connecting it to a PC? What’s the best way to convert the OMFI files to QTs?
    Thanks a lot!
    Quad G5
    2GB RAM
    OS 10.4.7
    FCP 5.0.4
    AE 6.5
    Marcosh replied 20 years ago 6 Members · 7 Replies
  • 7 Replies
  • Ben Holmes
    August 23, 2006 at 2:10 pm
    Have a look at Automatic Duck? You want the FCP Importer version.
    Ben
    Editec Broadcast Editing Ltd
    EVS & FCP specialists for live OB operations.
    Producer/Director “The Supercar Run” now available for international distribution from http://www.electricsky.com
  • Marcosh
    August 23, 2006 at 2:33 pm
    Thanks, Ben!
    I knew of Automatic Duck but as I had no intention os exporting a sequence/timeline and using the PC as a simple capture station I was hoping to bypass the software. Isn’t there a way fo converting the OMFI files into QTs in AVID?
    Will I have a problem sharing the same external HD between PC and Mac though?
    Thanks again!
    Marcos H.
    Quad G5
    2GB RAM
    OS 10.4.7
    FCP 5.0.4
    AE 6.5
  • Steve Cohen
    August 23, 2006 at 3:07 pm
    Is the drive Mac Fromatted or PC formatted. If it is MAC formatted you can use a program called MAC Drive to make the drive visable and usable on a PC.
    Steve Cohen
    Editor
    O2 Media Inc.
  • Jeremy Garchow
    August 23, 2006 at 3:17 pm
    My first question is why do this? Answer that, then we can hammer out a workflow.
    The best way quality wise to is digitize both projects on pc and mac with their respective codecs, then use automatic duck to swap timelines and reconnect, rather than trying to transcode a PC file into a mac quicktime.
    Jeremy
  • John Pale
    August 23, 2006 at 3:29 pm
    As you know, Avid uses OMF media files and FCP uses QuickTime.
    You can export Quicktime files from Avid, but they lose their timecode. There is a way around that using Sebsky Tools
    https://www.dharmafilm.com/sebskytools/workflow
    Frankly, its a pain in the ass…you are far better off doing what others have suggested using Automatic Duck. If purchasing it isnt in your budget, this might be a job you should walk away from.
  • Todd Reid
    August 23, 2006 at 4:07 pm
    I’m assuming that you would be finishing the project on your FCP and not migrating back to the AVID.
    I suggest having the company buy you an AJA Kona (or other input solution) and eliminate the PC altogether.
    It sounds as if you were only using it as a digitizer anyway. Too much of a hassle to do that.
    It would save A LOT of headaches/time if you just upgraded your system to ingest the digibeta.
  • Marcosh
    August 23, 2006 at 7:22 pm
    Thanks a lot for all the responses,
    Trust me, guys, if I could I’d avoid the PC altogether and have my laptop connected straight to the deck. I know how much of a pain is to change systems midway through edit. I just want t stick to my G5 and use it as much as I can. As I’m doing this as a freelance gig, I can’t impose the AJA purchase on them. That does sound like the best solution though and I may have to consider buying it myself.
    First, I’ll try Automatic Duck. Hope that works…
    Marcos H.
    Quad G5
    2GB RAM
    OS 10.4.7
    FCP 5.0.4
    AE 6.5
