Activity Forums Blackmagic Design Media Express Settings
  • Media Express Settings
    Posted by George Sey on June 11, 2010 at 10:32 pm
    I used Media Express today for the first time and was not impressed with the settings. Also there was not much information there too. I used Motion jpeg and the quality was bad. I used 8bit and 1hr was 78gb with great quality but big space usage.
    What is the best setting to use. In Premiere the rates are not bad.
    Andreina Marcano replied 16 years ago 3 Members · 3 Replies
  • Kristian Lam
    June 16, 2010 at 1:17 pm
    Hi George,
    What do you mean by settings? Can you be more specific?
    If you’re referring to the quality settings for MJPEG, then it’s currently locked down and is not user adjustable.
    However, the quality is good. There is the offchance that the wrong encoder is being called. Do you have any other “codec packs” installed on your system?
    regards
    Kristian Lam
    Blackmagic Design
  • George Sey
    June 19, 2010 at 6:49 pm
    I am talking about the quality of the settting as they are different from Premiere’s. I settled for the 8bit which is super quality. Only that I need more space as an hour is 77gb compared to Premiere’s 13gb.
    Thanks Kris.
    George
  • Andreina Marcano
    August 25, 2010 at 12:54 pm
    Hello,
    What codecs are used with media express?
