Activity Forums Adobe Premiere Pro Media Encoder Not Encoding Sound?
  • Media Encoder Not Encoding Sound?
    Posted by Nate Hanson on October 6, 2009 at 2:39 pm
    I’m using Adobe Media Encoder to make flash videos. The source files are Quicktime movies uncompressed from Final Cut Pro. The problem is that AME is not producing any sound on the finished flash videos.
    I set up two Watch Folders. One for 640×480, the other set to use source file’s size. Other than that, they are identical. In fact, the second one is a duplicate of the first with only that one change.
    At first, my “source sized” watch folder would produce no sound, only video. Now both of them are producing sound-free videos. Has anyone had this problem?
    Nate Hanson
    Pilothouse Films
    Vince Becquiot replied 16 years, 11 months ago 2 Members · 1 Reply
  • Vince Becquiot
    October 6, 2009 at 4:53 pm
    Well, this seems to be an annoying bug that I noticed first on someone else’s machine. And it had to do with using the Dynamics effect (compressor in particular), and possibly the EQ.
    Even one clip in the entire timeline with any of these applied causes the issue. I would select the entire timeline, then right click remove effects, check “audio filters”, and see if that solves your issue.
    I usually do sound outside of Premiere so I haven’t encountered the issue much, not sure if it’s consistent either.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
