Activity Forums Avid Media Composer Media Composer3 no deck vista64
  • Media Composer3 no deck vista64
    Posted by Joe Picard on February 18, 2009 at 11:16 pm
    Hello,
    I recently installed vista ultimate 64 and media composer 3.
    Every thing seems to work except I can’t connect a 1394 device at all. I am able to capture in other programs like adobe and edius. I had the same problem under xp pro, but was able to capture with xpress pro 5.6. That was ok because I could capture in xpress and edit in media composer easily enough. I can’t run xpress in vista 64.
    I thought the problem might be the nvida driver. I have a quadro fx 1500. I think that I was able to install the 169.47 driver despite it not being a signature driver. I verified it with RivaTuner but device manager still display that another nvida driver is installed. This could be the problem…
    I uninstalled and let window reinstall the Texas 1394 driver. In the past avid required a specific 1394 driver. I don’t know if this is still the case.
    Any advice would be great.
    Thanks you!
    Joe
    Joe Picard replied 17 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
