Activity Forums Avid Media Composer media composer software vs AvidExpress HD
  • media composer software vs AvidExpress HD
    Posted by Roy Schneider on March 12, 2007 at 1:13 am
    Hi All, Just looking for some info on Avids Software. What is the difference between Avid Media Composer Software and Avid Express HD. I will be using it on A Mac G-5 that is currently using Final Cut. A few editors are looking for Avid Software. Any Thoughts?
    Roy
    Dom Silverio replied 19 years, 6 months ago 2 Members · 1 Reply
  • Dom Silverio
    March 12, 2007 at 2:41 am
    Many little but the biggest are…
    Paint and Animatte
    more resolutions/compression available
    9 way vs 4 way multicam
    and minor UI differences:
    unlimited vs 3 lines of info for TC window
    center duration
    2 row of buttons/info on Composer window (AXP has only 1)
    reverse match frame
    basically the same:
    color correction
    FX system
    audio FX
    if you need a true 10 bit then you would need MC + Adrenaline BOB.
    AXP has partial 10 bit. And Mojo (either version) is 8 bit only.
