Activity Forums Avid Media Composer Media Composer 4.05 export to Bluray and DVD masters
  • Media Composer 4.05 export to Bluray and DVD masters
    Posted by Carey Weatherford on February 19, 2010 at 12:19 am
    We are finishing our first HD project since changing to Media Composer 4.05,
    running on a new dual quad Mac Pro Nehalem.
    It was shot in 1080, 35mbs, with New JVC 700s.
    We need to output to High-end DVD and Bluray masters. We can use
    Sorenson and DVD Studio Pro 4.
    What is desired is to set the software to use the entire DVD\Bluray disk,
    to ensure the least compression, highest playback resolution possible.
    Have you done this? Can you enlighten with settings, info?
    Many thanks,
    CW
    Carey Weatherford replied 16 years, 6 months ago 3 Members · 4 Replies
  • John Pale
    February 19, 2010 at 12:43 am
    DVD Studio Pro does not do BluRay.
    You will have to find something else to author with.
  • Carey Weatherford
    February 19, 2010 at 1:26 am
    Roger the no Bluray, many thanks,
    Has anyone else output a project like this?
    We would be grateful for any knowledge.
    Again thanks,
    CW
  • Jason Hunter
    February 19, 2010 at 1:47 pm
    You’re on a Mac so you have a couple of options. It’s going to be easier for you if your DVD is a auto-play disc than an interactive one as most of the affordable Blu-Ray authoring tools are suspect.
    If you just need an auto-play Blu-Ray see Toast 9. It will author those. Compress using the software of your choice (Sorenson’s okay, Apple’s Compressor comes with presets).
    Adobe’s Encore is another option. However if you need to author an interactive menu please see Walter Biscardi’s tale of horror.
    Good luck
  • Carey Weatherford
    February 19, 2010 at 10:15 pm
    Roger that, many thanks for the reply. We’ll check Biscardi.
