Media 100i 8.2.2 and Boris Graffiti 2.1
Posted by Andrew Wotring on February 24, 2006 at 3:38 pmI’m using Media 100i 8.2.2 and Boris Graffiti 2.1 when i creat a title in Media 100, and click on the edit button to edit the title, my media 100 crashes with one of those media 100 unexpectidly crashed errors.
boris doesn’t seem to have problems with out media 100,
i’ve trashed preferences of both applications, and run disk utility under osx.
does anybody have any other advise? thank you
andyAndrew Wotring
EditorFloh Peters replied 20 years, 5 months ago 3 Members · 8 Replies -
Floh Peters
February 24, 2006 at 3:44 pmHave you tried the Graffiti 2.1.2 updater that can be downloaded here (at the bottom of the page)? And what does happen if you start Graffiti without Media 100 (in Applications->Boris Graffiti)? Usually Graffiti tends to crash if you have a bad font in your system, but then the Graffiti keyframer will also crash when launched from the Finder.
And there is a “Boris Font Cache” file in your Preferences folder. Delete this also, maybe this got corrupted. -
Andrew Wotring
February 27, 2006 at 4:30 pmThank’s Floh, you always help me out, in answer to you questions, i did try updating to 2.1.2 thank you, and i assume you mean the boris Graffiti key framer. that seems to work. finally i did delete the boris fon cache file.
bad font in system… good idea, but i am very much a novice when it come to font management… however there’s a lot of font’s on that machine. could you give me a head start pointer or a website that may help?
Joey Wright
March 14, 2006 at 8:27 pmI am having the same problem. 1gHz silver door G4 OSX 10.4 Media 100 8.1 Grafiti 2.1.1
The Mac crashed when I try to create a title from the media 100 time line. This is all a brand new installation. I did not install classic when I installed the os. Keyframe seems to work ok. I delete the Media 100 prefs and the Boris Fonts Cache as well. Still locks up. Any thing else I can try?
Thanks -
Floh Peters
March 14, 2006 at 8:31 pmHave you tried the 2.1.2 update? If this does not work it is probably time to upgrade to Graffiti4.
Joey Wright
March 14, 2006 at 8:34 pmSorry Floh it was 2.1.2. So do you think it because I am using a later version of OSX than 2.1.2 can run under.
Floh Peters
March 14, 2006 at 8:51 pm[Joey Wright] “Sorry Floh it was 2.1.2. So do you think it because I am using a later version of OSX than 2.1.2 can run under.”
Probably yes. If the Keyframer works and if you create a new project in V8.2.2 and a new Graphics clip there crashes then there probably is an underlying problem. One thing you should check though what version of Graffiti is in your Media 100 i folder->Graphics. If there is something other than V2.1.2 delete it and reinstall Graffiti.
Joey Wright
March 20, 2006 at 3:03 pmHey Floh,
I downloaded the 14 day trail version of Borix Grafitti and it still locks up and wants me to power down.
I delete the 2.1 version of the plugin that was in the Graphics folder so all that is left is the 4.0.2 version.Here is what I have.
Media 100i – 8.0.1
OS – 10.4
Grafitti – 4.0.2 (trial version for 9 more days) -
Floh Peters
March 20, 2006 at 3:21 pm[Joey Wright] “Media 100i – 8.0.1
OS – 10.4
Grafitti – 4.0.2 (trial version for 9 more days)”V8.01 does not work with OSX 10.4 (or 10.3). Either upgrade to V8.2.3 or downgrade your OS to 10.2.x
