Activity › Forums › Media 100 › Media 100hd and Boris Red 3GL
  • Media 100hd and Boris Red 3GL
    Posted by Lukkee Chong on March 5, 2006 at 9:04 pm
    Hi all,
    I have just installed Red GL in our Media100Hd system and am having issues with the output. I am getting “jiggles”, vibrating titles on the output. I am working with the HD 8bit uncompressed setting, but it happens in 10 bit also.
    The system is mac OS10.3.9, dual 2.5 G5, 2 Giggs ram, Media100HD 10.1.3, Red 3.0.
    Appreciate the help.
    lc
    John Roberts replied 20 years, 6 months ago 4 Members · 4 Replies
  • Kieran Matthew
    March 6, 2006 at 2:10 pm
    These are just a few suggestions from my own experience with RED 3GL, you may well have been down these paths already.
    Firstly, check the field dominance settings are correct for Media 100 use, both in the general preferences and in the track settings – sometimes they get altered by preset effects.
    Secondly have a look at the local project settings in the Preferences, particularly the “better quality field rendering” – I have noticed that this setting, though recommended by Boris, sometimes has an adverse effect on some renders. Try a test with it on and off and see what happens.
    If the “jiggles” are caused by interlace noise, the 1:2:1 deflicker option can help, though this does produce softer output.
  • Bobby Mosaedi
    March 6, 2006 at 3:46 pm
    i experienced the same problem when installing RED on HD. easy solution – download and install the lates boris red patch. It addresses the media100 field dominance issue specifically.
  • Lukkee Chong
    March 6, 2006 at 4:35 pm
    Thanks for your help, I will check on the updates.
    lc
  • John Roberts
    March 9, 2006 at 6:24 pm
    I cannot get video clips to show up in my comp. I threw out the old comp, tried a new one, tried the keyframer, tried importing footage directly frome the harddrive but nothing seems to work. Any help would be great.
    Bo
