Media 100 Upgrade
Posted by Marcus Warren on June 28, 2012 at 7:09 pmCan we expect a Media 100 upgrade before the end of the year?
Gerry Condez replied 14 years, 1 month ago 7 Members · 16 Replies -
Marcus Warren
June 28, 2012 at 10:27 pmSince you asked:
– For Media 100 to be a 64 bit application.
– The integration of Boris Soundbite into Media 100 Suite.
– To play more file formats natively (i.e. not require the purchase of a third party program like ClipWrap).
– For Boris RED to have the new filters available in BCC 8.
– To be able to use animated black and white mattes directly in the Media 100 timeline (Like those available from FreedomFX. If there is a way to do that now ((without having to go out to RED)), clue me in).
– Faster rendering.
– Background rendering.
– Getting rid of the A/B style edit that only allow you to use certain effects on the V and V1 tracks. Presumbably you can recreate those effects on other tracks through RED, but I think that getting rid of the A/B workflow is loooong overdue.
– More tutorials on a consistent basis.
– A GUI that works better on a single monitor/screen. I get tired of moving things around.
– A way to customize the M100 GUI (choice of colors, save layouts).
– Additional built-in audio editing and processing capabilities, like those available in Apple Soundtrack and Adobe Soundbooth/Audition.
– A totally updated manual, including screen shots from the current version of the software and updated information (for instance, why does the manual continue to mention Pixlan Software as plug-in for M100, when Piexlan has not supported M100 (or the Mac)for years?)
– Much better marketing and much better support and information directly available from the Media 100 web site.
– For M100 to work with and be supported by a wider range of 3rd party hardware including solutions from MOTU. I read on this forum that some people are having problems with Matrox MX02 and Media 100. Get ‘er fixed!
– etc. -
Jason Tower
June 28, 2012 at 11:19 pmSame here, great points Marcus! I am one of the lucky ones to have a useless MXO2 with my Media 100 🙁
Jason W. Tower
Fiddler Films -
Floh Peters
June 29, 2012 at 12:00 pm[Jason Tower] “Same here, great points Marcus! I am one of the lucky ones to have a useless MXO2 with my Media 100 🙁
“Not sure if this really helps, but maybe you should get in touch with Media 100 Techsupport. As far as I know there has been some work on the Matrox side…
Jason Tower
June 29, 2012 at 12:19 pmI’ve been in touch with Matrox support for a couple of months now. In the last email I received from them on May 25th, they said that they’ve been in direct contact with Boris Yamnitsky and are trying to work the issue out. Unfortunately, as of today, there still hasn’t been a fix released by Matrox 🙁
Luckily, I held on to my trusty old Kona LHe board and it’s been working like a charm with the system! I just really miss the hardware up conversion and h.264 Max encoding on the Matrox. Going forward, I think we’ll end up having to invest in an LHi board (or Thunderbolt box if M100 will support it) and dump the Matrox box. AJA just seems to have their act together so much better than Matrox.
Anyone in the market for a Matrox MXO2 LE with Max?! LOL
Jason W. Tower
Fiddler Films -
Floh Peters
June 29, 2012 at 12:27 pm[Jason Tower] “I’ve been in touch with Matrox support for a couple of months now. In the last email I received from them on May 25th, they said that they’ve been in direct contact with Boris Yamnitsky and are trying to work the issue out. Unfortunately, as of today, there still hasn’t been a fix released by Matrox 🙁
“Again, not sure if this is of any help, but I heard that there has been done some work on Media 100s side to better support the Matrox 2.5 drivers. If this is what you are (or tried to) using, then you should get in touch with Media 100 tech support; I guess they could give you a beta version to test if this fixes your issues…
Jason Tower
June 29, 2012 at 12:35 pmI’ll definitely get in touch with Media 100 tech support and talk to them about the beta fix.
Thanks Floh!
Jason W. Tower
Fiddler Films -
Olof Ekbergh
June 29, 2012 at 1:32 pmTabbed bins and programs would be a great improvement.
Olof Ekbergh
