Activity Forums Media 100 Media 100 Suite v1.0.1 adds suport for AJA v6.5 Drivers
  • Media 100 Suite v1.0.1 adds suport for AJA v6.5 Drivers
    Posted by Wickham Strub on August 23, 2009 at 1:50 pm
    Here’s how my announcement post from Friday SHOULD have read.
    – Requires AJA v6.5 drivers* to run with AJA Kona line of cards, including the new LHi
    – Fixed an issue where transitions to and from a MultiClip where removed when choosing “Make Separate Clips from MultiClip”
    – Fixed an issue where HDMI input was not correctly indicated in the Input Channel Mapping window when using the AJA LHi
    – Fixed an issue where some files would import with their audio tracks drastically out of sync.
    – Fixed an issue where transitions between 1080p and 1080i clips would not render correctly
    – VoiceOver tool now shows correct CTI position when a record is aborted
    – HDx-based systems can now acquire 1080psf as 1080p
    – Improved 1080p playback to 1080i output with HDx cards
    – Improved support for Matrox MXO2 line of I/O devices
    * For those using FCP 6.x, there is some confusion about whether or not they can use the new AJA drivers. We have been told by engineers at AJA that FCP 6.x WILL work on the v6.5 drivers from AJA.
    Robert Stone replied 17 years ago 3 Members · 2 Replies
