Activity › Forums › Media 100 › Media 100 MPEG 2 export
  • Media 100 MPEG 2 export
    Posted by Fester on August 15, 2007 at 9:44 pm
    Hello there..
    We are relatively new to the great media 100 and we have a problem that we cannot seem to solve..
    We need to export a 30 second timeline to a file with the following credentials.. Could someone please help me in this task? the credentials is as follows
    Exporting the file to a 50 MB constant bit rate I Frame only MPEG-2 Program Stream direct from digital source.
    The problem we are having is that in the export codecs we cannot see MPEG-2? We even purchased the quicktime MPEG2 codec from apple.com
    Can someone please help us?
    Many thanks to anyone who reads / replies
    Stephen
    Juanjo Mora replied 19 years, 1 month ago 3 Members · 3 Replies
  • Floh Peters
    August 15, 2007 at 10:35 pm
    Media 100 does not include an own MPEG2 encoding routine, but it can use all QuickTime conversions.
    The best way to do your MPEG2-encoding would be to export a By-Reference QuickTime file from Media 100, and then do the MPEG2-encoding in one of the available MPEG2 encoders, like BitVice, Compressor, Episode, Cleaner or one of the other tools out there.
  • Fester
    August 16, 2007 at 11:51 am
    Hey there..
    Thank you Floh for your reply.. Is there a freeware MPEG encoder? doesnt have to be MAC.. its can be PC also..
    We are a non profit org so money is a little tight 🙁
    Many thanks
    Stephen
  • Juanjo Mora
    August 16, 2007 at 7:42 pm
    Hi!
    You don’t say what version of Media100 are you working on… but if you have access to a MacOS X machine you should try ffmpegX, I use it every day and its great! Also it’s free.
    You can get it here:
    https://homepage.mac.com/major4/
    Regards,
    Jj
