Activity Forums AJA Video Systems Media 100 is teriffice with Kona LHe
  • Media 100 is teriffice with Kona LHe
    Posted by Bob Zelin on June 11, 2007 at 2:31 pm
    being the typical prejudice guy that I am (FCP with AJA), I was amazed to see what a teriffic product the Media 100 HDe is, using the Kona LHe as it’s hardware engine. If only AVID could sign a deal (and not with Liquid !) for the Media Composer product to work with the LHe or I/O HD – the world would be a better place.
    I never thought I would say this, but good job, Artel (Boris) !
    Bob Zelin
    Matt Riley replied 19 years, 3 months ago 4 Members · 3 Replies
  • Walter Biscardi
    June 11, 2007 at 4:34 pm
    Media 100 is still my favorite NLE of all times both because of the simplicity of the interface and the quality of the video codecs.
    I still very much miss how simple it was to uprez an offline timeline. Simply select the timeline, select the resolution to capture to, select Batch Capture. That was it. And it ONLY recaptured the video and ONLY what was in the timeline. That was so simple and I have asked Apple time and again for the simplicity of this offline / online workflow.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • David Roth weiss
    June 11, 2007 at 6:21 pm
    [walter biscardi] “I still very much miss how simple it was to uprez an offline timeline. Simply select the timeline, select the resolution to capture to, select Batch Capture. That was it. And it ONLY recaptured the video and ONLY what was in the timeline. That was so simple and I have asked Apple time and again for the simplicity of this offline / online workflow.”
    Same with Discreet Edit* software, even going all the way back to its earliest roots in 1992 as D-Vision Pro, working under the DOS operating system. Its goes to show that onlining in FCP is about as archaic, in computer terms, as painting on cave walls.
    David Roth Weiss
    Director/Editor/Post-production Supervisor
    David Weiss Productions, Inc.
    Los Angeles
  • Matt Riley
    June 12, 2007 at 3:06 pm
    Agreed: FCP is frustrating to take from offline to online in the traditional sense (capture, edit, recapture).
    Avid DS makes this rather easy, allowing you to have multiple resolutions and compressions of your clips and awesome media management to let you purge and recapture whatever you want at any time, either from the timeline or from bins.
    Then again, if you are working with P2 or another file-based format (which FCP does rather well) then there is no need for an offline/online model, which is a beautiful thing. 🙂
    -Matt
