Media 100 and 4k
Posted by Gerry Condez on February 8, 2015 at 4:49 pmIm using kona 3g. Are the 4k files can only be imported? Can it be Acquired through sdi? Thanks
Floh Peters replied 11 years, 6 months ago 2 Members · 3 Replies -
Floh Peters
February 9, 2015 at 5:20 pmSDI input is only possible for HD (and of course SD) resolutions right now
Gerry Condez
February 10, 2015 at 11:04 pmThanks Floh,
Just to clear my question again with the format. So, HD is the regular HD at 1920×1080? Is that right? So I can only import 4K files, edit and whats next? Can I monitor them in regular HD monitor? Does Kona convert 4k to HD playback? thanks -
Floh Peters
February 11, 2015 at 10:38 amYou can monitor in HD (1080) via HD-SDI, and of course you can export as a file in 4k
