Activity Forums Adobe After Effects Expressions Mechanical fan with expression
  • Mechanical fan with expression
    Posted by Mio Tanaka on January 2, 2012 at 4:51 pm
    I made a mechanical fan whose blades start rotating and keeps the same speed after 1.5 seconds using AE at work.
    Although I am still a novice at Expressions, I managed to make two versions of basically the same thing.
    Below is the expressions I made.
    (to blades’ rotation)
    1:non-split layer
    if (time <= 1.5)
    thisComp.layer(“null1”).effect(“Slider Control”)(“Slider”)
    else
    value + time*900
    2:split layer (in point is at 1.5 seconds)
    this layer is split in two at 1.5 seconds and the expression is applied to the latter half.
    thisComp.layer(“wing01_01”).transform.rotation + (time- 1.5)*900
    Although I managed to make it, I don’t understand why I needed to subtract 1.5 seconds in the latter parentheses in the second expression.
    At first I did the opposite since the layer starts from 1.5 seconds.
    It might be pretty basic, but anyone care to explain?
    Thanks in advance.
    Mio Tanaka replied 14 years, 4 months ago 2 Members · 2 Replies
  • Dan Ebberts
    January 2, 2012 at 5:53 pm
    I think it might be a happy coincidence. If you wanted to make the rotation match the slider at the transition point, I think I’d do it like this:
    s = thisComp.layer("null1").effect("Slider Control")("Slider");
    tSwitch = 1.5;
    if (time <= tSwitch)
    s.value
    else
    s.valueAtTime(tSwitch) + (time-tSwitch)*900
    Dan
  • Mio Tanaka
    January 3, 2012 at 6:04 am
    Yes, it seems to be just a coincidence…
    Thank you for the clearer and wiser expression.
    It looks much more flexible.
