Activity Forums Adobe After Effects Expressions Measuring width of objects in precomp
  • Measuring width of objects in precomp
    Posted by Yan Trudel on June 19, 2017 at 3:57 pm
    Hi everyone,
    I dont post here often since a lot of times I find my answers on the forums from other people facing the same challenges. Thank all of you guys for all the knowledge you guys share everyday.
    I’m working on a project where I’m building a template for editors to use to put in the day and time at which shows play.
    That info then appears in 2 boxes that are side to side. Depending on the input text, the width of the combined boxes is always different.
    Here is what it looks like :
    My question : can After effects calculate the total width if they are inside a precomp and how could i go about doing that?
    Thanks in advance!
    Yan Trudel replied 9 years, 2 months ago 2 Members · 5 Replies
  • Dan Ebberts
    June 19, 2017 at 5:26 pm
    Hard to say exactly without knowing more detail, but probably something like this:
    r = comp(“your precomp name”).layer(“your layer name”).sourceRectAtTime(time,false);
    r.width
    sourceRectAtTime() is the key.
    Dan
  • Yan Trudel
    June 19, 2017 at 5:41 pm
    Thanks for the quick response Dan! By the way, you’ve been answering so many expressions questions I have had over the year so thanks for that too!
    I had actually tried sourceRectAtTime() but since the result of those 2 boxes is precomposed, it gives me the width of that composition.
    In my current build I use sourceRectAtTime() for each of the boxes with the text; one is right aligned and the other left aligned. They are in different compositions that are then juxtaposed. I’m actually trying to figure out the total length so I can always center the result of the combined width of the boxes since it can vary a lot :
    Although maybe my approach might be where I’m going wrong here?
  • Dan Ebberts
    June 19, 2017 at 5:47 pm
    I was assuming that you would use comp() to target the precomp so that you would have access to the layers inside.
    Dan
  • Yan Trudel
    June 19, 2017 at 5:52 pm
    Oh, rookie mistake!
    I’m going to try it out now!
  • Yan Trudel
    June 19, 2017 at 6:07 pm
    Thanks Dan!
    Since I’m not the expert, I sometimes forget I can reference directly into comps… Seems like it was rather simple but greatly appreciate the help! ☺
    I’ve used the expression you gave me to measure the total width like this :
    j = comp(“Precomp_JOUR”).layer(“boite_jour”).sourceRectAtTime(time,false);
    h = comp(“Precomp_HEURE”).layer(“boite_heure”).sourceRectAtTime(time,false);
    h.width+j.width;
    Now going to work on getting it to center automatically. Thanks again!
